shiney targa bar
im currently renovating a 79 sc targa. the targa roll bar cover is painted black and quite franckly i think it would look much better in the brushed aluminum u see on earlier cars. (some of the paint is coming off anyway). can i strip the paint off and leave it bare metal without any corrosion worries? has anyone on this forum done this and have any top tips? and finally, does it mean im sad that i want to cut some of the metal off the braket that holds my battery in place just to save weight?
answers on a postcard.
Craig don't heitate to go for the shiny Targa hoop look. In case you don't know the roll bar is covered by a thin aluminium shroud or hoop. If you just clean off the paint and leave the metal bare then you will have to constantly polish and protect it . A good wax every month would probably do it. The problem with this approach is that the areas you can't polish without removing the hoop will be subject to nature's call.
My bar is a custom black satin finish (a tad of satin added to the original colour) just use a good clear laquer in your case. Unless you have a large oven you won't be able to do this yourself as the paint needs to bake on for toughness and longevity. Find a reputable body shop and to save money do the disassembly and reassembly yourself. The place Iused charged £100.00 , the problem painting the bar is it needs to be 'etched' and this can be problematic for some paint shops it would seem.
The bar is held on at the point where it joins the body inside the wing by two bolts and washers either side and also by a row of smaller screws aroundthe fronttop of the bar. You will need to remove and replace the Targa hoop front and rear seals, take pics with a camera so you put things back exactly as you removed them. If the seals and hardware have seen better days replace them for a refreshed look and extra weather protection. Coat the seals in vaseline , this makes them expand and protects them too. Two pairs of hands are better than one for this job as it is easy to scratch the bar or your car's body, ask me how I know!
i dont mind cleaning the targa cover every month, (its mine and i'll polish it as fast as i want) but i must admit to feeling a little disturbed by 'the forces of nature. what sort of corrosion/damage would an aluminium cover suffer from? Could i use laquer from a spray can? would this be suitable or would it rub off/ deteriorate?
_____________________________
bones
does this mean that the early targas with the shiny finish were also of aluminium, with a clear laquer finish. I had allways guessed they were stainless steel
On this one have you ever heard of anyone changing a black look targa to the early chrome look. I have thought about it for mine but have not found anyone to sell the chrome trims around the front and rear windscreens
thanks
jonathan
Well I've always been a little confused about this too , until recently I thought they were stainless steel but when I removed the bar for painting as it was black, lightweight and the underside was unpolished and looked like aluminium and the paintshop said it was aluminium I took them at their word. Now you have said you think they are stainless I think I will change my mind back to your way of thinking. Scrap all that I have just read it is polished stainless steel....der....
Well we've established it is polished stainless steel on the cars that had that finish from stock so I assume the painted hoops are stainless to but not polished. In which case go ahead and polish up the hoop as an original polished stainless item and wax it like the paint. If you want an eye popping almost chrome look use 'Speedy' metal polish it is the best metal polish I have ever used, get it at Speedy metal Polish
Get in touch with Peter Cook the club archivist and see if he knows whether the original polished stainless Targa hoops were laquered or not and then decide from there. If you don't use the car as a daily driver then you may not have to laquer it.
