Shell Nitro thoughts
- Thread starter Dave928
CarreraRSR
I've used Vpower Nitro and Momentum99 in the last few weeks and can't tell the difference. The wallet can as there's been 10p/l difference at my local Shell v's Tesco.
As with oil and tyre threads, I'm sure there's lots of divided opinion from the yay and nay camps on fuels. But for now the 99 octane gets my cash versus the 98 octane (assumed as I can't find confirmation on this on Shell.co.uk)
There has been a long thread on Pistonheads somewhere which has a lot of input.
Incidentally, on my BMW diesel the standard Shell Fuelsave diesel is significantly better than the VPower diesel, by about 4 mpg.
Ah, found the PH thread.
http://www.pistonheads.com/gassing/topic.asp?h=0&t=1275275
CarreraRSR
ORIGINAL: Lowtimer
Ah, not the thread I was reading earlier. I turned off when someone quoted they noticed the difference in running Optimax diesel in their Rover 25!!
Tref, as for better mileage on premium fuels, I don't believe it. I have historically done 35k in my daily diesel. Some tanks do 500 miles, some 600 miles regardless of fuel source. In a previous job the fleet manager banned us from using premium fuels as in his 'educated' opinion the added mpg v's cost was negligable, even on high milers.
I prefer to use 99ron fuels in the 924T just for added safety margin versus a 95-97ron version. In the daily diesel I now buy the cheapest
andy watson
Moderator
Now with the "M" everyone rates Shell,, my car runs on Momentum far better than the Shell
I don't think there is any set rule, each engine and driver feel is different, what suits best is what goes in the tank!
ChasR
On my dailies with normal NA engines I cannot tell much of a difference. Maybe it is smoother etc. but I cannot say for sure. Even on my Stag I cannot tell a blind bit of difference. My 944 S2 seemed similar as well.
A number of NA engines I could tell a slight difference, but they have their own caveats. My 106 GTi was not really any better on V-Power but my 306 GTi-6 was (it would pink ever so slightly at the very top end with 95RON and not on V-Power (that car was meant to run 97RON though). On a friend's Lupo it picked up better at the top end and it also extinguished his intermittent EML light which he had always had. Again, that engine was predominantly meant to be run on 98RON (something none of us knew until we checked the inside of the petrol filler flap in addition to the handbook! FWIW it was the 1.4 16v Sport (although strangely enough, the GTi is designed to run on 95!).
The Turbo of mine seems to respond better on V-Power (pulls better at the top) and I understand that with a Turbo car it is wise to run with a bit of knock protection in mind. I know a friend of mine with a 2006 Octavia vRS said his car was alot nicer to drive on V-Power over 95 (more torque, more MPG and superior top end performance). But they also have adaptive knock sensors to counteract pinking and advance the ignition timing a little further where possible).
Carrera RSR, I guess you are still on a distributor system and K-Jetronic (assuming this is what Turbo cars come with?)?
Lowtimer, I found the same thing with my 2006 VW Passat 1.9 PD TDi despite it being the lower power version (105BHP) It's ok on normal diesel, but it really does seem to have more go with VP-N especially with the torque (if I am honest the spread of torque in this car could teach most TD cars a thing or two about getting usable power from a diesel despite the lack of BHP!)! It smokes less too! A friend's Alfa 147 JTD smokes less on VP (you can guess what he does come MOT time) but to me and him (I previously owned the car) it did not seem to make much difference at all in terms of performance.
The N/A 944's have a knock sensor I understand, which means there may be an explanation for the fact that they benefit from higher-octane fuel, although that depends upon how the knock system is set up and how advanced the timing is set by the system. If it advances it as much as possible until it knocks and then backs off a little, this will mean it will benefit from higher-octane fuel. If it just runs at a fixed setting and only backs off if knock is detected then the benefit from higher-octane fuel will depend upon what this fixed setting is.
ORIGINAL: ChasR
Actually, I'm saying the exact opposite. For my late 2008 320D, the "ordinary" Shell fuel is clearly superior to the "premium" one. I get consistently better fuel consumption (and no discernible difference in performance) on Fuelsave diesel (the cheaper fuel) than on VPower diesel.
Driving economically - yes, I can do that - but that makes significantly more difference than this - no, I wasn't interested in saving a bit of fuel in a fuel crisis, I'd not be driving the S2 if I were, the only time I usually drive like that is if I am out of fuel late at night trying to get to the next petrol station (or on the space-saver - which offers the most significant fuel saving!) In truth, the fuel crisis was the opposite - a chance to make progress as the roads were empty[
There are some other amusing anomalies, but again reproducible... with me driving it is typically more economical towing my little box trailer, and despite a blat up to an indicated 155 and cruising around 90-100, I got something like an extra 5mpg on the German Autobahn. Both are explainable.
I really must get the LPG system connected up...
That'll be the day Tref!!! Anti-terrorist squad have your card well marked.[I really must get the LPG system connected up...
Copperman05
Edd
Veerzigzag
ORIGINAL: Veerzigzag
My car runs much smoother when it's clean.
You noticed that too, eh? [
http://www.porscheclubgbforum.com/tm.asp?m=606798&mpage=1&key=bass򔉎
Tony
CarreraRSR
Marketing Monkeys 1 - Petrolheads 0 [
I couldn't believe the difference with the nitro stuff!
I didn't notice it had changed to nitro when I filled up, just went to my normal pump, drove home 1 1/2 miles, went out the following day and wondered what had happened, it was that night I saw the adverts, and then checked out Pistonheads.
Made a definite improvement to the smoothness, not sure about MPG as I probably drive it harder as its smoother
