Second winter of work begins - Fuel lines, brakes and welding
diabloam
Did majority of the welding last winter and thanks all for helping me locate correctish jacking points, golf ones have gone in plus have done back underneath battery, there a couple other bits and I have black calipers stripped and new bolts etc, need to free them up.
My attention turns to the fuel lines which I pulled off couple years ago now at the back and intend to now replace them all. There are couple reasonably priced hoses for the rear and I am going to get a roll of both 10mm and 8mm pipe and I am going to try do them hardline all the way up front wheel arch and to bulkhead and then flexi from there, thinking of turning the regulator round so both connections are facing back and pipe will be well away from above manifold. However, despite loads info online I am struggling to 100% ID connection going to damper. I see waleswood selling a jumper line that seems good value. However the other engine bay ones I wish to do myself. So 8mm return is jublee clipped to regulator but what connection is to damper, I read somewhere it was -6 JIC or something but its hard to work out. Probably do the rest pipes in AN6 but can anybody let me know what I need for damper. I know on other side it will be hardline to an^ connections but no idea what damper actually is, many thanks in advance for any pointers
is it something like this I need
AN -6 (-06JIC ) Male to M16x1.5 Female Swivel Adapter Fit Bosch Regulator BLACK
I want her to get one last MOT before she turns historic in Jan 2026 and no longer needs one.
Out of curiosity I emailed Porsche Aberdeen to see about recall on jumper hose all the same, not heard anything back, lol, car way past too old to honour it?
I have a couple of those fuel damper connectors on ebay right now, the same ones that Lindsey Racing uses on their braided fuel lines. These ones are for 6AN braided rubber hose, and there is two of them to make up a fuel damper hose. Check my build thread "Another 944 Turbo Engine Rebuild" for details of the custom lines I made.
You can get all the other hoses and lines you need from Torques UK in Abergavenny (see link below for ebay shop).
If you don't fancy making the fuel damper hose yourself, I can make it up for you with black nylon braided rubber hose and those connectors for less than the waleswood one.
Hi, yes would be interested in your damper line if you fancy making them up. However I am doing my mates also so would need two of them if possible?
As for the main feed connection to the damper, I think I will need to make them myself as going to try hardline up through arch and to bulkhead and then make flexi lines from there so bought ones wont be right length. I am going to rotate the regulator so connection to both it and damper are facing rearwards. However I am still little confused with the main connnection to damper and to convert to -6 AN hoses. What connection is that, think I need a metric 16x1.5 globeseal or something or is it just normal metric? Do you know if this would fit and allow then just a AN hose to fit that
or would ATEC 643.012 one you mention in posts the correct one for the straight connection onto damper
Great writes up of your turbo build, getting me motivated to horse on with my own. Fuel lines on and back running would give me a boost to get on with rest so trying trying sort that, many thanks for your help, appreciated
The damper connections are M16x1.5 metric, so the adapter you posted above will fit, as will the ATEC connectors. The bonus with the ATEC connectors is that they don't need an adapter, however they can be expensive. Last time I went to order some connectors from ATEC they were around £30 each!
Hi, ok I see your point, the ATEC 643.065 will go straigh from the damper connection to PTFE hose AN fitting and so nothing required in between. I actually got the tools off a mate to make up hoses so could do that with the connection you suggest. Were you just having to ring them up to order from them or is there somewhere online you can order them? many thanks
Here all done, used anti corrosion epoxy primer, then seam sealer and then stonechip. Will paint over that with chassis black after, coming along
