bmnelsc
Hello all. I need to do some work on my 1991 S2 clutch (95k Kilometers) primarily due to release bearing and guide tube. Options are sachs clutch kit or kits with PowerFriction disc and sachs pressure plate/TO bearing. the PowerFriction discs claim 30% more clamping power and significantly more lining. Anyone tried these discs? Worth using or does the larger disc create problems?
Or - anyone used Spec clutch kits?
My use is as a road car - don't really race it (although if the clutch/trans works better I might be inclined to try a track day
Thanks in advance...
