nick9one1
I've go a few issues that I think may all be related....
My S2 takes a while to start, it turns over fairly well but takes a while to fire up. This seems to be on both cold and hot starts.
Sometimes (not very often) when hot starting it sounds like it has caught, then splutters and dies.. it might do this twice before it fires up properly.
Idle is a bit high and slightly rough, wandering about 100rpm.
Once its running its fine (never stalls).
[blockquote]I've tried a few things already..
Re-tracked the AFM
Cleaned the ICV
Replaced Spark Plugs
[/blockquote]I noticed today that the high idle is probably a sticky throttle cable. When you pull the accelerator back with your foot it dops to 950 rpm (although still lumpy). So can probably cross that one off.
[blockquote]After some research I think it could be any of the following..
DME Relay
Distributor cap
HT Leads
Low fuel pressure (does anyone know the thread for the fuel rail end cap?)
Leak down test (probably not this but would be good to remove the possibility)
[/blockquote]Any other suggestions would be appreciated!
Re-tracked the AFM
Cleaned the ICV
DME Relay
Distributor cap
HT Leads
