s2. Rough starting, rich, wont warm idle.
simch1
I have an 1989 s2 cab, pre cat, no O2 sensor.
100k miles now, do 2-3k a year in the summer, it is pretty much untouched motor wise, had it's belts done about 6 years ago, but the rest is original never been undone form the factory. Just get it out each may, sticka battery on it, MOT it and off I go!
Anyway, all was fine this year, but this week it seemed to be susing a bit too much fuel and I notcied the back of the car was a bit sooty round the exhaust. BUt was due a service, plugs etc, so didnt think too much. Then last night, went to start it, and it was misfiring on start, very rough running on the gas, revving it up just stuck loads of balck smoke out the back and some blue too (blue smoke has been normal tbh on this car, for years, I think due to old valve stem seals, but after 30m secs it all clears and has always run fine). After much revving it settles down and runs on 4 again, and settles down to a perfect 900rrm idle. Drive the car, very fluffy, lots of black out the back, but open her up and it clears and goes fine. BUT on the overun, it seems to pop a bit out the exhaust...then come to a junction and the idel is all over the shop, 900drop to 250rpm, back up to 900, horrible.
So now it seems the cold start is rough and it runs very rough after first start, need gas to get it to start too. BUT, once it is going, it idels fine, then as it warms, idel goes to pot.
My thoughts popping on overun could be weak mix, maybe rich too, but usually weak. Cold idel suggests it is rich mix, and poor idle when warm suggest rich too..? I pull the plugs, they are jet black, sooty soo and sos! Now I know where ll the fuel has gone!
Done lots of searchin on here at Clarks.
Pulled the ICV pipe off the rubber boot from AFM earlier, and it is sucking lots of air through there, from cold. so looks like the ICV is not blocked at least. And suggests it is open, blocking the pipe makes it stall or run rough.
checked all vaccuum pipes, all look ok, and pulling the vac pipe off the vac reservoir up by OS windscreen pillar and it pops, suggesting it is holding VAC in there.
Going to change the DME temp switch as it is cheap.
ICV is not cheap!
Also, suggestions that it may be fuel pressure reg, causing very rich mix, but surely if these fail, they fail open and just return all the fuel to the tank, loosing pressure in the rail. It runs ok under load and high revs, so unless it has failed "shut" and the fuel pressure is goign ape and too high at idel, I am not sure.
So anyone had these symptoms.
Rough cold start, missing that clears, lots of sooty smoke out the back. But when clears it will idel ok.
Drives a bit fluffy, but power is there, but then as warmed, pops on the overun a bit, then wont idle.
Using too much juice and sooty plugs.
FPR? Fuel Damper? DME relay? DME temp swich? ICV (idel stabiliser) ? AFM??
Where best to start?!?
Any help appreciated.!!
cheers
I hate to say it, but could it be the head gasket? Mine was like that when it went. Sorry. There seem to have been quite a few of these recently...
Hmm, don't know how that (HGF) would make mixture so rich?? Tonight i checked the Fuel pressure regulator, and when the car was running, and hunting up and down on idel when warm, I pulled off the vac pipe to it and fuel was pissing out of the FPR when the vac pipe goes. So I reckon it is goosed, (diaphram gone) and fuel is getting sucked into the vac system and then into the inlet mani, making the mixture rich. I am pretty sure that no fuel should be coming out of that orrifice with the motor running...?
Sure hope so! Ordered a regualtor yesterday and damper as well, so hopefully if the courier turns up on time, i will have her back to her amazing self this evening!! Even treating her to a new dizzy cap, well the one on it is 14 years old!! rotor arm should do another 14 years though!! :)
I would add that if she had her belts done 6 years ago you should seriously consider getting them replaced asap.
Yes, they were done at Machtech and it has only done about 10k since. Had all the tensioners and cam chain roller done too, all very good! But called them yesterday to ask about them replacing the belts, (hopefully the rest will be ok) to be told they dont work on 944s anymore! :rolleyes: So was going to ask Autofarm to quote for it, but always went to Machtech as they had a guy that seemed to really know what he was talkign about regarding the 44s
ORIGINAL: simch1 Yes, they were done at Machtech and it has only done about 10k since. Had all the tensioners and cam chain roller done too, all very good! But called them yesterday to ask about them replacing the belts, (hopefully the rest will be ok) to be told they dont work on 944s anymore! :rolleyes: So was going to ask Autofarm to quote for it, but always went to Machtech as they had a guy that seemed to really know what he was talkign about regarding the 44s
It's an outstanding decision from JZ, they upset a lot of owners when they refused to work on the water-cooled older cars. They seemed to forget that people are loyal to the brand, often owning more than one car or progressing up the chain, and won't be taking their newer cars there either. [:'(] Where are you based? There are other options not far from JZ.
I'm in Oxfordshire so not far from autofarm or Bob Watson. Anyone nearby me apart from them worth a try, or will travel if it is worth it of course.
Just to confirm, replaced the fuel pressure regualtor today and all is back to perfect with the s2. £90 all in, and ECP transferred it from Wembly branch to MK same day so I could pick it up, all FOC. I got refunded from GSF, which is fair enough, they were a few quid cheaper than ECP, but no good if the stuff doesnt turn up when they say...!
