S2 owners with abs issues
Waylander
A very comprehensive and useful write up, thank you. Its not just the S2 systems but also the Turbo and 928 systems, most of the 944 ABS bits are 928 parts.
I would add in though that from my recent scrutiny of electric diagrams and botching of ABS/ Brake sensor looms, the ABS system isn't earthed at the wheel sensors. The small brown wires that come out from the cream 'barrels' or connectors are linked into the pad wear sensors system not the ABS.
Yours
Chris
You are totally correct the little brown wire can be reattached with a self tapping screw as it's the earth for the pad sensor and I also know they are nearly £100 for each cable.
Also on the 968 the ns abs sensor also drives the signal for the speedo
