Hi guys
It's only a matter of weeks away before I can start to tackle the fuel pump issues on my S2. I have a very loud fuel pump which needs changing, an intermittantly failing fuel sender, and a corroded fuel line. There is some good info on the clarks garage website, and I hope this, combined with a 944 Haynes manual, will help with my first effort at back garden mechanics (that's not intended as a smutty euphamism!).
Clarks says "A clogged fuel filter can cause failure of the fuel pump. A failing fuel pressure regulator can also result in pump failure. It's a good idea when installing a new pump to perform a fuel pressure check and pump delivery rate check". is this an easy job? Can I achieve it with something as simple and cheap as this? Is there any advice you can give around this area?
