Hi all.,
Hope you don't mind me picking your brains, looking at replacing the rear exhaust for at Carnewal GT Exhaust, thought it would be a simple job, but as you know that never transpiers, so I thought it might be a good idea to start to remove the exhaust this weekend, in preparation for your replacement one.
However I've a problem with the 4 bolts that connect the rear exhaust to the Cat/manifold. Is this a real worry??
As you can see from the picture, the nut has rusted and basically disintegrated (which seems to happen alot after reading a number of forums) and also on the cat/manifold side it's completely round??
Any suggestion on how to get theses undone??
If they are cut off flush to the flange, will the remainder of bolt knock through towards the cat/manifold??
Thanks in advance for advice ??
