Running with the cam cover off?
You'll never know all the mechanical niggles until you have driven it on the road, got it properly hot and run it hard up to the rev limiter in all gears a few times. As said, I think you may well cure as many problems as you find by doing this; they don't take kindly to being laid up or only used occasionally (as me how I know.)
Have you compared your S2 side-by-side with another known-good S2? They should drive very smoothly, but mine has always sounded a smidge rough at cold idle but it's no better nor worse than any other one I have come across.
For what it's worth, I'd get the bodywork sorted out, a nice shiny new MOT certificate procured, and then drive it a bit. And don't worry about mechanical things not being quite as they should be until you have some miles under the wheels.
