Having some problems I just can't iron out. If anyone can shed some light it would be very helpful. I spent 2 hrs sorting all the vac leaks yesterday and the car runs better and probably nothing wrong with my wastegate. I also checked play in the turbo and all seems well, so I don't need a new turbo or wastegate as I thought in my last post.
Anyway my problems are:
If you blip the throttle from idle, so only get to about 2k revs the engine stumbles and takes a second to rev up. Also if you floor the throttle from idle like you're trying to pull out of a junction fast, nothing happens for maybe a second or two. Lastly if you don't roll on the power the car seems to just not go like it should. But if you roll through 3k revs then floor it, it pulls like a train. Any ideas??
One thing to note is the exhaust is blowing at the turbo as a stud is snapped, could this cause any of the above??
Thanks,
Tom.
Thanks,
Tom.
