ORIGINAL: craig2105
I've read loads about these RSR mufflers but I'm not sure if I've ever actuually heard them in use. I emailed Gert and got an excellent response from him, but before I order I think I want to hear them for myself.
Hi Craig,
Sorry I'm a bit far away, but hopefuly this info. will help. I fitted RSRs a week ago and I'm delighted with the sound. I expected a low, boomy exhaust note, but what I got was quite different. The sound is much more "tubular" and very characteristic. It sounds quite different to other non-Porsche cars with sports exhausts and is certainly not intrusive inside the car. You also get a slightly lower "growl" at idle. I'm delighted and the car sounds like I think it always should have, without any antisocial decibels.
Gert is really helpful. I got new RSRs. He's offered me 200 euros for my old boxes. Make sure you check to see if you need new heat shields though before you order. Mine were shot. Also, your bumper stays might be rusted through, so change those whilst you're in there for an easier life. My nearside muffler/silencer strap bolt was completely seized, leading to some fun with the grinder on a Sunday afternoon, so make sure you leave time for this & have a replacement bolt/washers/nut before starting. I found a Black & Decker "Dremmel" type of tool to be invaluable as you will probably find it's easiest just to cut through the clamp bolts. Good luck!
