VanhireBoys
Hi All
Just a small story this time ! This involves our old acillies heel sensors !
A car I have had the previlage to work on (No body knew and didn't want to know) had a no start issue which I correctly diagnosed as a faulty Ref sensor . I recommended 2 and outlined the pitfalls before leaving the lads to get sensors and fit !
Well the bracket got broken in the ensuing removal and a new one got - the replacement sensors got fitted without setting and the ref sensor got clipped !
So another sensor got and set up properly this time ! Everyone confident and key turned only to clip the sensor again
I then come on a scene of 2 clipped sensors a broken bracket and forlorn looks !
I took a look and I'm no expert but to me the bracket was fully extended and couldn't go any more ! I figured that 1 because the sensors were getting clipped that the bracket was bent from the first start 2 the sensor needed a washer to space it
So I found a lovely 0.8mm copper washer and put it under the sensor as a test ! Turned the key and up she went
This isn't as designed and ECP haven't sold a Bosch sensor like them for 20 years only to sell 4 in the last month to the same customer ! Sommit just dosen t tally and although the car is going I'm not that enthusiastic !
So Did I miss sommit obvious given my limited experience ? Has the bracket got damaged ?
Thanks a million in Advance
