Roof and any other hidden water drainage holes
TomNauntonMorgan
Can anyone supply pictures, videos etc of where these mysterious drain holes are?
Perhaps I need a worship manual?
Cost me an arm and a leg to get my Boxster S dried out so don't want to go down the same path again!!!
Tom
toptastictom said:
...Perhaps I need a worship manual?
Maybe worship is a going a bit far.
I know the 993 is divine, but wouldn’t want to turn it into a deity [:)]
Tom.
Look at the Parts PDF catalogue. For you can see the drain parts. Page 366 item 20 drain from Targa Roof, Coupe sunroof drain, page 361 Item 11 & 12
Hope this helps
Graham
Front sunroof drains go down the A pillar and under the side wall carpet to discharge under car, very easily damaged when scuttle repair is done, pretty much impossible to repair. I just blocked mine off as I had a leak for 3 years and couldnt repair it. Rear sunroof drains go down the roof gutter and discharge in the engine bay, they are a also a pain if the hoses come of the end, they then discharge under the back seats.
Where is it wet?
