Evening all
My 1994 993 C2 has had a rather annoying suction/vacuum noise since I got it. Over the past month or so I’ve tightened (cable tied) all the vacuum lines, cleaned out the ISV, reseated and cleaned the MAF, tried it without the air box cover, tightened all the jubilee clips and I’m out of ideas!
Could anyone suggest what I try next?
Video here:
https://youtu.be/KqBKJP7oTzk
As you can see it doesn’t happen in start up, only on blipping the throttle, it also happens when the throttle is held steady at 1800-2400ish rpm under load. It seems to happen immediately on the throttle moving so it could be the throttle body itself? The system appears to hold vacuum.
Thanks all in advance!
Video here:
