Has anyone had experience of replacement windscreens being smaller than original? I am having one fitted to my C2 Cabrio but it was about 1/2mm short each side at the bottom. The top fitted OK. I was told this is happening even with OE even if you can find one of them. The one that being fitted to mine was a Pilkington.
Replacement windscreens
- Thread starter rodneyhj
Yes exactly that. Once rubber surround is on its 1 mm too small all around. Had mine done at great OPC expense to avoid any issues but they even had audacity to colour in the metal gap with some sort of detailing colourant so the problem was hidden from me initially.
Of course they claimed it was normal to see fitting differences.
I need to get it removed and the area rust treated.
My Targa had it's first windscreen from new done at Swindon OPC in May 2019. All was good new OEM Screen and seal but there a little wind noise but with Covid haven't managed to go back for them to fix it. I also now have a rust patch that wasn't there. They checked when they took the original screen out and there was no signs of rust so again going back under warranty for them to fix
Graham
Graham
