I'm in the process of replacing the two air con condensers on my 987.2. I have purchased Behr-Hella parts from a well known national (or possibly European) parts supplier. Just tried to fit the backing frames and have discovered the replacement condensers are 10mm less in width and 5mm less in height compared to what are believe are the originals ?
Is this what I should expect ? I could modify the backing frame to fit but I’m not keen to do that. I’ve also noticed the new condenser mounting brackets are not consistently orientated so this may cause further fitting issues if the backing frame is used.
I’ve not read of any issues with fitting the Behr-Hella parts before, so I’m a bit surprised.
Thoughts please and suggestions on sourcing good quality, reasonably priced and correctly dimensioned condensers ?
