Remap S2
- Thread starter J4CKO
Diver944
Don't expect more than a couple of extra bhp to the maximum power but most people report a much smoother power delivery throughout the lower rev range
Peter Empson
Edited to add: Paul beat me to it. These S2 owners are quick!
Oh, and do they need Super Plus unleaded instead of normal, the previous owner said he always ran mine on Super but I have put it on a diet of Morissons finest unleaded and it hasn't made any difference.
Diver944
A shudder on downshifting is more indicative of some slop in the drive train, maybe the rubber centre of your clutch is starting to break up (very, very common). I don't believe a remap or chip is ever going to cure the problem you seem to be having
Peter Empson
I would want to choose a chip intended to run on super, it makes sense to me as there are obviously gains to be had with higher octane fuel, after all car makers dial in a fair amount of safety margin as standard. I would also want to know who and how the chip was developed, a known chip might be twice the price, but knowing you have something properly developed (and safe) is surely worth the extra?
I will look at the Promax chip, seeing as its a recognised one, guess with cars this old all the R and D was done years ago so there is no saying who did what and when and who deserves any royalties.
With regards to the fuel, the car will still run ok I guess if you put Unleaded in it, its not going to start pinking and running like crap is it ? not sure if they have knock sensors or anything like that ? would you just lose the benefit rather than ending up with a car thats not running right.
Anyone actually had it done ?
Peter Empson
About the judder, one area that the standard cars are quite bad is when you come off the throttle, there's very little fuelling and can result in kangarooing in traffic when you really want to seamlessly change speed. I suspect it helps mpg figures, but in the real world I always found it better after this was engineered out, presumably becuase you can keep a more consistent speed. I'm not sure it's quite what you're experiencing, but might be a possibility. I'm not sure if Promax still do a money back guarantee if you're not satisfied, but if they do it could be a good experiment.
Diver944
ORIGINAL: J4CKO
I used to organise a 944 Rolling Road day every year and if you look at the results for normally aspirated owners then cross reference the registration number with the spreadsheet below you will find a lot of them already have chips of some sort - Promax, AMD, BBS, Blitz etc
http://www.cannell.co.uk/944%20UK%20League.htm
I've never bothered modifying my S2 but it's having its yearly service next week so I might just get the Promax chips at the same time. I'll report back.
Oli did a really good writeup concerning chips in his S2 a few years ago, worth a read:
http://www.porscheclubgbforum.com/tm.asp?m=541717&mpage=1&key=chips򄐕
http://www.porscheclubgbforum.com/tm.asp?m=541717&mpage=1&key=Promax%2Cchipò„•
I almost always use the higher-octane motion lotion in my S2 (with the Promax chip), but have never had a problem with using more pedestrian stuff when necessary. (I maintain that the higher-octane stuff is a good economy; yes, it costs more per litre, but you get better MPG out of it, and the ensuing cost/mile is about 10% lower - but that's a separate discussion!)
ETA: Blast! Smiffy got there first again! You're really quick off the block on this thread Paul - bravo! [&:]
ETA (again): Paul, the Promax chips are well worth having. I'm sure Andrew will fit them for you as part of the service (it's a fiddly job - a good one to let someone else do) and will be happy to give you a full refund if you don't like them.
Diver944
ORIGINAL: zcacogp
Mr S get his hands dirty
Peter Empson
ORIGINAL: zcacogp
ETA (again): Paul, the Promax chips are well worth having. I'm sure Andrew will fit them for you as part of the service (it's a fiddly job - a good one to let someone else do).
It's nothing a mallet and a hacksaw can't sort out, or have I been doing it wrong [
TTM
Well-known member
This was identified by a German contact of mine who has been working on this issue directly with engineers from Sachs.
They did supply him with a prototype clutch disc that seems to have cured the issue completely, but I'm yet to hear of a date for it to enter full production - I doubt there are tens of thousands of 944 NA owners that replace their clutch every year...
ORIGINAL: J4CKO
shifting down into 2nd on a closed throttle,
If you are changing down on a closed throttle the engine is on the over-run cut-off and has no fuel being supplied, so no power is being produced whatsoever. There is no way for a change of ignition or fuelling map to affect its behaviour in that regime.
The remap does sound compelling, cheers for all the info, I did several searches, mainly via Google but didnt turn much up.
Think I will get the numbers off the ecu this weekend and get one ordered.
