rear shock lower bolt
- Thread starter 944Turbo
Sure Sulzeruk or Elliot would have one.
Super_Marv
Bigger question is, why did the original bolt go walk about? [:-]
I had a feeling they were quite a large metric fine thread, will take the other one out and down to my local fastners place, but they tend not to have so much metric fine hardware available though.
Incidentally with no rear shocls the rear is really bouncy ( moved my lux without rear shocks and it was like a trampoline) with one disconnected it is nowhere near as bad.
cheers,
Tony
ORIGINAL: zcacogp
... and what was the bottom of the shock absorber resting on without a bolt to keep things where they should be?
Dangling!
Jonny944CS
Give Doug or Mark a call at Exeter PC (01392 822841), mention the forum and you'll have a nice fresh new one within a few days - freepost.
Not sure what Damper you are running, but one thing I did notice when fitting my KWs - the extra width of the lower body clamp meant the original bolts were barely long enough for adequate thread engagement.
After a quick search though PET I found an M14 x 1.5 x 100 flange hd (900 378 051 09 - normally used on a GT3) "" ordered it and it fitted perfectly.
Thanks for sizes as I can now go and sort the problem
Tony
