Dear all,
Thanks in advance for any light you may be able to shed on this little fault.
I noticed yesterday that my rear nearside brake light was out and thought this would be an easy fix.
When I removed the old bulb it had clearly blown. However, after replacing it yesterday it still won't work. When I turn my main lights on the bulb lights up as per normal so clearly it is getting a power supply. However, when I depress the brake pedal the brake light filament glows red without coming on fully. I have tried several other bulbs of different makes and still get the same result.
The spoiler brake light and offside light are both working normally.
Any ideas on a solution would be much appreciated.
Kind regards
Gerry
Kind regards
Gerry
