rear fog lamps
jtparr
have just put the car, 1982 SC Targa Sports through my first MOT, generally all is fine except I have to re-fit the (staggeringly ugly and crude) rear fog lamps, that I removed within the first hour of ownership>
They look like something normally associated with Mk II Escorts from the 1980's
I beleive I can upgrade to a more integrated solution by using some parts from the 3.2 Carrera vintage
Has anyone done this and if so is it difficuilt
Oh yes, I removed the front ones too as they are equally awfull looking
thanks
Jonathan
Jonathan,
I upgraded my 86 3.2 Carrera to the integrated fog lamp rear from the 87 model year.
The single below bumper light look awful, but I now have two lights either side of the Porsche reflector.
PCT in Coventry did it whilst doing a service, but there's a simple article on the web about where you need to drill the mounting screw holes (simple Google search).
Reflector with integrated lights is not too easy to find (but can still be found new buty pricey), but I sold the original reflector and fog light (to a chap in the USA).
Email me if you need any pictures or help.
I had this done to my SC several years ago; fed up with knocking off the under bumper mounted ones. Inow have integrated fogs in the reflectors. The unit came off a mid 1980s Carrera, so I was told.
Behind the original reflector is a panel; which had to be cut to allow the rear of the light units to project through the panel sufficiently for the reflector panel to sit flush.
A bit of wiring extension also needed, nothing major.
A worthwhile mod in my view and not really too difficult for reasonably competent DIYer. Though I had it done because I did not have enough time (still dont) to do things like this. Hard enough to find time to wash the car.
Could be worth making up a stiff cardboard template first so that the outline to be cut out is clearly and accurately defined.
Good luck
