I need both the above or at least the rear section, apparently the RS rear section is different part number to the C2/C4, if so how would they differ as I am sure either will do? Tried a few breakers no luck and a heads up would be appreciated .. Thanx again.
Rear Bumper Irons and Section needed.
- Thread starter carreraboy
About £400 plus vat ......
rear irons and bolt on alloy internal bumper section .... is there a second hand one out there? RS one marginally more expensive than C2/4 new but must be more plentiful on second hand market. The fixing Irons are cheap enough and will get these new as they ALWAYS RUST ..... [&:]
All sorted ... got them from a VW Breaker .... identical to late Beetle!
Steve Brookes
Moderator
ORIGINAL: carreraboy
If you want to take the opportunity to add lightness while you're at it, you can get aluminium fixing brackets:
FVD aluminium bumper support brackets
