re-mapping S2 ECU
- Thread starter eddieedmo
chrisg
However......
The last run of the S2's were known as SE's in an attempt to sell them - they were fully loaded with AC etc, AND were remapped by the Factory to put out 225bhp = ~ 7% more power than the standard cars. So with the right chip/map, filter, possibly MAF unit and exhaust I'd be surprised if you can't get ~ 230bhp from a non-blue printed or flowed head S2 ?
Thoughts or comments from the S2 group ?
Suffolk944
Moderator
http://www.porscheclubgbforum.com/tm.asp?m=541717&mpage=1&key=chip%2Coli򄐕
The topic has been discussed here several times, but I'd re-iterate that the chip isn't about power figures; it's about mid-range torque, which it does rather well. I'd be very surprised if you couldn't get 230bhp from a good S2 lump (Promax claim more than this I think with their chip, having seen one car with it fitted getting some very good figures), but a BHP figure is a bit meaningless. The big gains are smoothness and torque, with ensuing mid-range flexibility, making for a significantly brisker car to drive. (Prior to fitting the chip I'd not uncommonly end up with the car jammed on the limit in 2nd and third, shouting at it to go faster. Post chip-fitting this hasn't happened once.)
I didn't realise you'd fitted a turbo at the same time... [
peanut
The important thing to note is that this engine delivers power right through that band evenly. There is no sudden surge of power or tailing off . Because of this the engine doesn't seem to have the speed and aggressive acceleration that other cars seem to have .
BUT this is deceptive. The S2 just delivers the power quietly , evenly without fuss and as everything else falls away behind you , you realise just how quick it is. My understanding is that the 944S2 isn't so much a sports car but more of a GT grand tourer and as such the gear ratios and transmission has been designed accordingly.
if you are looking for a 'peaky' screamer you've definitly chosen the wrong engine.
david924s
eddieedmo
Thanks for all your replies.
Nick [
pauljmcnulty
I guess I need to have a ride in an un-chipped S2 for comparison. Mine has no noticeable "peak" to the power, just pulls through the rev range very smoothly. Maybe it's just comparing it to the "s", which I had a good long drive in and really does have a torque curve that's either on or off, and needs to be kept above a certain point to be going anywhere at all. [8|]
If I felt the need to do anything to an S2, it would only be a de-cat and a chip from Promax. Their chip has been around for a long time, and I've never heard of any complaints. Can't see how spending far more on a custom re-map could get you anything as good.
david924s
ORIGINAL: Alexw
Sorry to hijack, but I was looking at doing a live remap by Wayne at Chip Wizards I think it was but I can't find his website or anything else of his - is he still going?
I had my 968 done by Wayne, and yes he is still going. Whilst a live re-map is the best and Wayne is top drawer at re-mapping I chose a Promax chip for my S2. If you are only going to use your car on the road and the odd track day then the Promax chip is very good and you can spend the £200 you save on petrol and have fun.
If you have modified your car, port & polish etc then Wayne is your man.
Big Dave
ORIGINAL: PJS917
ORIGINAL: Alexw
Alex. I second all that PJS has just said.
Have you checked your PM box.??
