Rattling exhaust.
john.carter2
I've a Macan GTS with a rattly exhaust. It's from a small broken metal plate linking the 2 pipes in the centre of the car. What's this plate for. Should it be welded. If it has no purpose, then can it be removed.
Looks like a spacer piece to stop the main pipes flexing, especially when fitting the exhaust. As exhaust is fitted and it's broken probably won't make any difference removing it. Otherwise see if your local garage can spot weld it at the break.
