Put a few bit on eBay. There's more 2 come
- Thread starter T3rra
ORIGINAL: T3rra
eBay name is t3rra0169 not sure how 2 get links from eBay via smart phone and app.
Just incase Anyones watching or needs any extra info
Terry
Hi there , are the navy coloured seats a pair in the same colour ?...... also are they straight bolt on to the 944 standard seat runner and electrical connectors for the driver's electric seat ??
Do your oval dash vents hold their position at any angle ? ( as mine keeps dropping when i have them in the higher position ! )
cheers.............Mike
Both seats are electric and even if yours arnt the wires should be there.
Vents, what do u mean? Are we talk about the main vent next 2 the clocks? Cas that is fully functional
Check under the seats and can take a pic, MIT even have one from when I put them in.
Sorry the vents? You say 2 do you mean ones at each end or the big centre one? If we're talking about the centre one, mine works. Can't think what would be the cause off the issue you have.
ORIGINAL: T3rra
Seats, yes, think its 2 or 3 wires, join the wires 2 the same 2 wires and leave the others will
yes its the main one in the oval dash.....when putting the sliders to the upwards postion the sliders will not hold that position (I guess because of wear and tear , i.e the mounting point as lost its grip on the attach point ).
thanks for the info .
I wrote a how 2 on another forum I use.
Basicly the runners remain. I just used a differnt part off the runner 2 fix to floor with. Think I only need 2 drill one bolt hole out off 3 per runner.
I removed the gas strut Cas it catches the floor when sliding the chair back past the shallow well. There point less on are cars as you don't need the hight adjustment, which is extra 50mm up and fillwards which at 5,10" made me feel 2 close 2 windscreen. The gas Srut could be re wield in a slightly higher place. Or you could pack up the seat base 2 allow clearance.
Removed they sit same high as 944 seats.
Oringal Seat belt retanters are used
And the wiring 4 the electric tilt is easy
Seats are simpler in hight and width
nick9one1
(boxster and 996 seats are the same)
http://forums.rennlist.com/rennforums/924-931-944-951-968-forum/590484-boxster-seats-will-fit-a-944-a.html
http://forums.rennlist.com/rennforums/924-931-944-951-968-forum/52357-completed-boxster-seats-to-944-conversion.html
http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/373980-boxster-seats-944-2-a.html
http://944hybrids.forumotion.com/t281-996-seats-in-an-83-944
