Problem found.
Mark 944
I have a '91 944 S2 which has had a drain on the battery for a while. I heard a clicking coming from the fuse box and found the relay for the electric windows clicking away. Has anyone else found this before and if so, what do i need to do to fix the problem.
Mark.
Try the courtesy light switches in the door shuts. The electric windows can operate with the ignition off when the doors are open.
The windows will work from the (drivers side switches only) with the drivers door open, without the key even in the ignition. so there is a connection there and Simon is usually right!
