944Fripp
Ok, so I know most 944's groan but I wanted to ask, the ones that do groan do they groan at slow speed on close to full lock in BOTH directions? Mine only does it when I'm turning left...any opinions/ideas? Determined to get to the bottom of this as sometimes it's unbearable!
The fact that it only happens when I turn the steering one way would suggest it's not the power steering system right? So is there anything else that I should be looking for?!
The other thing that is fairly new is that the drivers side window now sticks about a 3rd of the way up. Sometimes it jumps and carries on but when it doesn't it is pretty well jammed. I have to pull it up to free it and then it'll go the rest of the way.
I've had the door card off and can't see anything in there which would stop the movement and the teeth on the gears seem to be all fine. Any ideas folks?!
Ta!
Ta!
