I have been told by my garage that my car has a 'flat spot' and has suggested that the problem is with the 'hall sensor' in the distributor. It appears that it is not possible to source this part to repair it and that the only solution is to replace the distributor. Porsche are quoting £1600 + VAT !!! Has anyone had a similar issue and more importantly been able to source a replacement sensor?
Porsche 993 Carerra 2 Distributor
- Thread starter emyrmorris
I guess they may have some sophisticated analysis tool that tells them it's the hall sensor, but if you have noticed it not running perfectly I'd suggest changing the HT leads first/distributor caps. When I had them changed it transformed my car.
Have they said which distributor? I'm not sure what the hall sensor does and I wonder if both distributors have one and the price is for changing both.
Relative had similar hall sensor issue years ago and I sourced a replacement sensor from RS components.
They removed the old sensor and then we identified the replacement from RS.
Also found a company at the time that refurbished distributors but can't remember their name and didn't need to use them in the end.
My understanding is that Porsche only sell a complete 993 distributor set and have heard this is on a refurbished basis, so thinking Porsche are getting them refurbished.
Hope this helps
Hope this helps
T911UK
Hall-Effect Vane Sensor CYHME56C, Output: NPN (OC), Power Supply: 4.5 V ~ 24 V DC, Alternative for: 2AV54, 2AV16A, 2AV51A, 2AV56 (Honeywell)
ChenYang Hall-Effect Vane Sensor CYHME56C is designed to work in the conditions of automobile environment. The device is produced in compliance with…
Thank you for your reply. I understand that they have checked HT leads and the caps but has been diagnosed to the sensor. They are going to try a refurbished distributor which they had in stock and see if that sorts it out. There is only one sensor as I understand which is on the 'main' distributor. After some research the sensor detects the position of the rotor within the distributor.I guess they may have some sophisticated analysis tool that tells them it's the hall sensor, but if you have noticed it not running perfectly I'd suggest changing the HT leads first/distributor caps. When I had them changed it transformed my car.
Hope this helps
Many thanks for your reply and assistance. We are trying out a refurbished unit but will take up the suggestion you have made from RS Components wo see if there is a fix solution. As I have been told that everything else with the distributor is working ok I might have a spare distributor for sale very soon!!
