poor running
DavidL
I've not used my car much since the starter change etc, weather has been grim etc. I've started it and run it a couple of times but it is reluctant to start from cold, spins fine (as it should now) but I have to try this 2 or 3 times. When it fires it's a bit ticky but I put that down to lack of use but the revs surge to about 2k. I can blip the throttle a couple of times and it falls but climbs back up. Not the throttle sticking but that's about as far as I've got. No change as the engine warms. It will restart when warm ok.
I'll take it out if it ever stops raining and see how it drives. It was a bit lumpy when I did but again lack of use maybe.
So does that sound like anything? Most stuff is new ish apart form maybe the fuel pump.
Yeah vacuum lines or ICV or ICV plumbing was my first thoughts. TPS possibly, could also be AFM related. I would start on those areas.
Try disconnecting the throttle position sensor. I ran my turbo like that for years, due to the ridiculous price of a new tps.
Thanks. I had a read of Clarks and vacuum lines and AFM were on the list. I can't see any issues with the vacuum lines, most are fairly new. AFM is brand new but ICV and TPS seem possibilities. I shall check.
