Playing music from iPhone 7 in 997
- Thread starter Blowfish
i had the same challenge with my 997.2 . Your options are
1. Buy an iPod connection cable which should connect into the aux and usb ports and creates an iPhone 4 style fat wide connection.. so I bought a light connector to convert it to an iPhone 6&7. It works and allows you to select music from the pcm system but it means that centre console won’t close as the phone and cables don’t fit in their with it closed and I did find the connection intermittent..
2. Buy a headphone jack and just use the aux out.. you won’t be able to select the music on the pcm but works better than option 1 in my opinion.
3. You could get a rqdio connector and try that which a friendly Porsche opc said is the best and cheapest option. I am yet to try it myself but it’s as simple as tuning your radio into the frequency the radio connector generates.. you will have to choose the music off your phone though
I am not sure on a 997.2 if there is a way of bluetoothing music I am afraid and pretty sure Porsche would only suggest option 1. Happy to be corrected on any of the above but the 991 onwards allows Bluetooth and Spotify music interface.
pete
My solution was to buy a secondhand older style iPod and keep it connected in the Centre armrest using option 1 above. It cost me £10 from a Cash Convertors type place on the high street and came "clean”’with factory reset and 3 months warranty. It had enough memory to provide a varied enough collection for long journeys.
Doesn’t really help with Spotify though.
Stephen603
I have just done a video on this topic, Bovee 1000 is the way to go to solve this problem.
https://youtu.be/VLiZz57pABY
Stephen603
Having said that if You are using waze on yr iPhone the voice prompts will come through as well.
