The date on my 2004 996 turbo PCM2 is wrong and i cannot correct it even with a PIWIS or PST 2. The problem started about a year ago when the date would sometimes not show when the unit was on and would either appear later or if I pushed the 1, 4 and 8 buttons together to soft reset the system. The problem then recurred when I re-started the car later.
However, over the last 2 months, this is no longer an issue in that the date is showing all the time as it should except it started on 01/01/2000. I am now on 26/02/2000 and I used the PIWIS and PST 2 to try to code the date in the MMI module but it didn't even change. When I did it in the Navigation module, it corrects on the screen for 10 seconds then reverts to the pre-corrected date.
Any advice would really be appreciated if anyone else has had the same problem and how to correct it.
