PCM 3.1 keeps restarting
laura
I don't know if any of you have had this problem. The PCM 3.1 on my 2013 BoxsterS restarts every five or ten minutes which is very irritating. I have done a factory reset which I have seen recommended on the internet - that made no difference. Does anyone have a different solution that works?
Mine did that probably 6-7 years ago. Couldn’t find any local repairers and at that stage there weren’t many Internet sources who could confidently predict that it was a hard drive failure and document how to replace it. In the end I sent it to https://www.pcmrepairs.co.uk/ who diagnosed a logic board failure and (expensively) fixed it. Worked faultlessly after that and it came back with new maps installed. Since then I have seen quite a few people apparently solve the problem with a new hard drive, but that’s not a trivial task especially if you want to replace it with an SSD. I know there are more local repairers familiar with fixing this at more sensible prices so may be worth you enquiring with car audio/nav specialists near you. Good luck!
