PCCM upgrade
Dont think it affects the stopwatch - that works independently of the head unit. I though the loss of sport chronos functionality with regard to PCM is the lap timer / display in the PCM.
I have replaced my pcm 3 unit with an aliexpress one - the stop watch and dash display for chronos still work fine - I cant imagine how that would stop wth the PCCM+
No, I’ve lost sport chrono entirely.
Using the function lever to select the menu in the dash the Chrono function is now missing.
That means there’s now no way to operate the stop clock.
There are still the old trip functions, but the lap timer and stop clock are no longer available.
I’ve queried this with Porsche and good to know your stop clock at least still works, I do feel aggrieved that the stop clock is now an ornament
I spoke with Porsche Swindon about the Sport Chrono issue, they went away to check and confirmed that it should still be available. It’s going back to them to do some re-coding. I’m still not clear if it will retain the lap time capability but at least the stop clock should work.
Some more news. My car (997 GTS) also has Bose, and since the installation the sub woofer is no longer functioning either. I'm pretty sure all the other speakers are online, but the sound is not good so I'm wondering if there's another issue here. I also had the iPod USB/aux adapter in the centre console, that no longer works but I have't yet checked if the USB still has power
It's back at Porsche Swindon today, so we'll see.
So more news, the stop clock is now working, but the lap time function is missing, as is sound quality.
Could anyone that’s had this done let me know if there’s additional parts needed for the Bose system? I think I read that somewhere
You could ask the lads at Friends Green Porsche who've fitted a few of these now according to the video I posted further up the page? Seems like they know their stuff.
I've posted a couple of questions on the video - that was helpful so thanks for posting
Also they confirmed today that the sub woofer is not working, they refitted the old PCCM and now the sub woofer doesn't work with that either! They recoded for the new PCCM and apparently can't now code in the old unit.
Further investigation is underway!
Yes - you need a fibre optic converter for BOSE but without it there would be no sound - so I guess its in place.
Sounds like there's been some talent failure going on - if you had a PCM before there's as far as I can see there is no new coding required for a 997 - the Porsche install doc (all be it US based) is here: https://static.nhtsa.gov/odi/tsbs/2026/MC-11035929-0001.pdf - if you have lost functions from the cluster then I would guess they have decided ( for some reason ) to do "Basic Coding" of the cluster, rather then "Managed/Guided coding" - but I don't see why they would have needed to do that - since the only coding I see in the install doc is "tell the car it has PCM" - which if it did then there was no need to touch it
There is a requirement to update the PCM to the latest software before you swap it out - that can actually update the software in the AMP - which the new unit doesn't support - so perhaps they missed a step there.
Whatever has gone on - you certainly shouldn't be having to teach them how to do it, hope they sort it properly and quickly for you.
Sounds like you'd best get down to Reading OPC to give them a hand malarcy! Appreciate it's the first unit they've fitted but shouldn't there be some sort of training given before they start fitting these units? Sounds like they're having to try and learn on the job at the moment.
No problems Berin - hope they can get it sorted for you or at least send it to someone who knows what they're doing.
Thanks, I think it’s the part ends 580A, which is fitted.
OPC Swindon are now waiting a new sub woofer from Porsche. It worked when it went in, and now doesn’t work at all even with the old PCCM refitted
Interesting. They have recoded, twice now - once on the original install that lost the sport Chrono and again when they added sport Chrono back but lost the sub.
Hi all has any one recently upgraded the old PCM or a Chinese one if so did you go with CHSTEK, Heregoes or other brands ? My car has Bose was it easy to connect the Most adaptor and what gb did you go for ?
thanks
Col
