sawood12
I've got an issue with TC on the SMax and anticipating the usual un-helpful response i'll get when I take the car into the dealer to look it over - i've already had the usual "We've hooked it unto the diagnostics computer and it came up with no fault codes so we can't do anything else" at my last service when I asked them to look into it. I'm taking the car back to them as things seem to have got worse and I want to approach them with some semi-educated ideas as to what may be causing the issues as it is just getting silly now.
Previously the TC on the car hardly ever cut in, even when I was driving the car in a 'spirited fashion', and it only cut in at expected times - i.e. when pulling out of a junction quickly or when on snow and ice. There are a number of corners around me that you can take at high speed, where the TC now cuts in a good 15mph earlier than I could take the corner previously without the TC cutting in.
It could very well be that the TC system itself is working fine and something else is kidding it into thinking that something is wrong.
This all started to happen after I replaced the rear tyres so my first suspicions lie with something to do with the rear tyres. They are the same brand and correct size as the older tyres. At first I thought that maybe they were slightly slippy due to releasing agent or something on the surface of the tyre, but this should have scrubbed off by now.
I'm wondering if something else may be triggering it for example a worn bush or something that may be causing an effect that I can't detect, but the TC system can? Has anyone got any experience of mis-behaving TC systems on other cars? I know it is a long shot.
Thanks.
Thanks.
