old idle thread
muzz
I have a 1987 Porsche 944 with a 2.5 16v. When I first start it idles high, after a few seconds it idles rough at low rpms. It drives fine when hot but whenever I come to a stop it will either drastically drop in rpms and then shoot back up to 850 rpm or stalls.
I have check the temperature sensor and that is in ohms limit at all temperature ranges, I have battery voltage and 40 ohms at the auxiliary air regulator and the valve closes at start up, Idle air control valve works when a 12 volt is supplied.
I know its an old thread but can anyone help
When my S2 did this, it turned out to be a perished hose to the idle control valve. It was cracked underneath where you could not see it.
I'd do a smoke test on the vacuum system . There are so many little inaccesible places for a small leak to screw your mixture on idle.
Also check the AFM resistive track around the low throttle position.
Also possible you have a leaky injector or possible faulty engine temperature sensor
The ISV valves gum up over time, that will cause bad idle.
Also have you checked the throttle position switch is reliably sensing you've got a closed throttle, if not the DME will not know to start using the ISV
