scam75
Well-known member
Well I had promised myself that I would start running a fully synthetic oil after my recent engine re-build. The car got a 10/40 semi after the re-build to run it in and now I've covered over 1k miles I decided to do a change and put in a full synthetic. I got a good deal on some Lucas 10w-60 full synthetic and what a difference it has made. Hot idle is now just over 4 bar whereas before it was just under 3 bar and I would say that oil pressure has probably lifted by one bar across the range. Also my noisy tappet has almost completely disappeared as well so it would seem that the old girl is more than happy with this thicker oil.
I assume it's perfectly normal to see these changes in pressures because of the difference in oil quality and grades?
Stuart
Stuart
