Oil Pressure
- Thread starter Guest
wedgepilot
wedgepilot
sawood12
This oil pressure thing seems to be a very common debating point but I can't recall ever reading a thread where it is an actual problem. The oil pump on 944's appears to be 100% reliable as far as I can tell. Is it just a case of the fact there is a gauge then people take notice of it and ask questions about it? I've never had a car before with an oil pressure gauge and i've never spared a second thought about oil pressure and I still don't in my Focus, but even I find myself mesmerised by the dancing needle in a obsessive way. Sometimes ignorance is bliss.
If you oil pressure is usually around 4, and one day it drops to 2.5, that is something to be investigated.
If, on the other hand, it is usually around 3, don't worry about it.
(I quite associate with the story about adding a gauge to cars which didn't have them. Similar experience here.)
Hilux
I would guess that oil pressure warning lights come on at about 5psi ish and crank pressure can be even lower before the oil film breaks down. The main indicated psi is the head pressure required to circulate a viscous liquid around the engine in quantity so as to remove heat and not `burn` the oil. Low pressure means that the gaps in the engine are larger therefore the head pressure is reduced BUT if enough oil flows its not an issue. Its when the pump cannot maintain a head of pressure that the oil light illuminates but there is still oil flowing albeit at a critical volume.
However when an engine is revved hard with low oil pressure the increase in heat is then a cause of oil failure as it is not flowing quickly enough to dissipate the heat or to create a protective film.
Thats as I understand it. I would also suggest that the OEM gauge is wildly innacurate when put up against a properly calibrated specialist gauge but is probably better than most mass produced cars. Ironically the more gauges you have the more there is to worry about. How ever did we manage with just a little yellow light [
When I was a young, newly-licensed nipper, my folks had a Pug 205 with two gauges - speed and fuel. And a few warning lights. (Damned good thing it didn't give any more detail really, given the way I drove that car ... beaten like an illegitimate ginger stepson would not be over-stating it ... !)ORIGINAL: Hilux
How ever did we manage with just a little yellow light []
"The oil pumps on these cars are generally bullet proof. When they go bad, it's generally the result of losing prime to the oil pump which can destroy not only the pump but, the main and rod bearings as well. Again, this is one of those things that you can't really test for. All you can really do is remove the pump, disassemble it, and inspect the pump gears."
Could the belt coming off the bottom crank shaft pulley to the oil pump cause a loss of prime?
Tony
Botton crank pulley torqued to 155 lbs ft and belt tensioned 5mm deflection as per manual. We have 3 bar pressure at 3000RPM but drops off in and out of the red light. No bottom end rattles only noisy tappets which suggests the oil is still not getting to the top. Any suggestions for a reduced pressure?
If i have a look at the oil filter and find foreign objects this would suggest engine damage , If no foreign objects then a damaged oil pump could be the problem. does this sound feasible?
As Tony states the front pulley is the key and presumably yours came off. You don't have to prime the oil pump in any special way and it should quiet the top end quickly if all is well so I assume something else is still awry if the pulley is back as it should be and you still have a problem.
Even so the idea of swapping an engine is drastic as it may be something relatively minor and you won't get a good 250 engine for £200 like you might with one for something like an Escort.
Worst case scenario is a rebuild and I've been suitably scared off from an independant for rebuild costs (£2000-£4000 not a realistic price!). I can source a new engine for £1200 with history. How long to fit @£60 p/h.
Never had to get my hands that dirty with any of my cars engine wise and only carried out basic maintenance. Looks like i'm going to be learning pretty fast. How muxh of the engine can you take apart with it in situ?
