chrisg
Tim to answer your questions: What it does - as the name implies it it regulates the oil pressure within the engine. It's actually very simple a spring-loaded plunger with seals on. Once the oil pressure reaches a set level, it pushes past the plunger and the pressure drops. Most of the time its more like a steady trickle and regulation. What can go wrong - spring inside the plunger starts to fail leading to lower pressure, most commonly though the rubber o-rings at the end of the valve start to perish and it won't hold the same level of pressure. What symptoms you get if it fails - most commonly low or erratic oil pressure Hope this helps, Chris
