oil pressure relief valve
- Thread starter Guest
chrisg
to answer your questions:
What it does - as the name implies it it regulates the oil pressure within the engine. It's actually very simple a spring-loaded plunger with seals on. Once the oil pressure reaches a set level, it pushes past the plunger and the pressure drops. Most of the time its more like a steady trickle and regulation.
What can go wrong - spring inside the plunger starts to fail leading to lower pressure, most commonly though the rubber o-rings at the end of the valve start to perish and it won't hold the same level of pressure.
What symptoms you get if it fails - most commonly low or erratic oil pressure
Hope this helps, Chris
timmyturtle
So if i am doing engine work its probably worth cleaning/changing the seals?
I currently have 4 bar at idle after a 10 min journey,a little bit more when cold.
robwright
ORIGINAL: timmyturtle
Thankyou for the replies
When hot your idle sould be around 2.5 bar and around 4.5 - 5 bar when cold. Somtimes the valve can stick and cause high oil pressure. Well worth doing for the cost of a new O ring, which you could probably source for pence.
