oil pressure relief valve alignment tool
tom_babbs
Probably been asked before but i couldnt get the search function to work properly so i will ask again, sorry.
Do i need to get an oil pressure relief valve alignment tool in order to change the oil cooler transfer gaskets on a 1989 3l s2 engine as i have serious milkshake in the coolant and need to sort it out.
Thank you in advance Tom
Some people say you can use the relief valve itself to line everything up. I think that there is a tool floating around on the forum that can be borrowed though.
