I'm found a notable amount of oil in my intake manifold when doing some maintenance yesterday. The rubber boot that connects the AFM to the throttle body had oil in the ribbing and the rubber where the breather hose connects to the boot is perished. The evidence would point to oil coming through the breather system. I have removed the breather pipe from the boot and sealed of the hole. As far as I am aware the crank case breather system goes to the manifold is to reduce emissions so it should be fine to let the pipe vent to atmosphere.
Any suggestions as to why oil might be coming up through the breather system? I thought maybe the crank pressure was high but I checked cylinder compression and its showing over 150psi on all 4 cylinders. The consistency across the cylinders would suggest to me those readings are good. I'm not sure how much pressure to expect though. The following calculation suggests it is spot on:
Compression ratio = 10.6
Atmospheric pressure = 14.696psi
14.696 * 10.6 = 155.7776psi
Tom
Tom
