Oil for 944 turbo SE ?
- Thread starter 9212PT
sawood12
bmnelsc
For a full discussion see this link http://www.lnengineering.com/oil.html
M1 0W/40 would be one of the last oils I'd use. Even in the UK you get some fairly warm to hot Summers.ORIGINAL: bmnelsc
Porsche recommends Mobil1 0-40 full synthetic for pretty much everything. Supposedly the 0-40 blend has extra ZDDP as per Porsche requirements for wear protection (recall the valve guide issues of 2.7 thru 3.2 flat 6s). I can't confirm the extra ZDDP part but I recall reading somewhere that the 0-40 blend was concocted to meet Porsche specifications.
There is plenty of good info on that link you've posted to Charles Navaro's site. Well worth spending some time to check it out.
944 man
That the oil is synthetic isnt the issue and discussions here frequently seem to end up in that cul-de-sac: the results would be the same if those grades were available in mineral oil.
Strangely, Silkolene Pro-S 5w- fully synth in my older 1985 engine = virtually no usage at all.
sawood12
ORIGINAL: bmnelsc
Not for the 944 they don't - the grade that is. And Porsche have about 30 oils on their approved list, Mobil 1 just pay them shed loads of cash to recommend them and put that oil in their cars on the production line and at services - what they don't tell you is you can take along your own oil so long as it's on the recommended/approved list. It is a bit like Finish dishwasher tabs and Zanussi! Ferrari recommend Shell oils, Mobil is just one brand of oil.
