A topic I have replied to a post in the 996 forum, but during a couple of thousand miles road trip in Europe, I noticed NVH on different roads at higher speeds (95+) in my 2007 C4S tip cab, 74K miles, new Lemforder OEM engine mounts, new Michelin PS2s all round, all suspension arms renewed 4K miles ago and no rattles. 4 wheel alignment by Meteor Motorsport after. No shaking through the steering wheel at all. What is the collective view? It is 'perfect' at British road speeds. It's not awful, but not as smooth as my A6 used to be!
NVH at high speeds
- Thread starter Hillbeley
Hi,
For a high speed vibration you’d have to suspect that it may be driveshaft/transmission related. Since there’s no vibration at the steering wheel it could be the rear driveshafts, or since yours is a C4 then maybe the propshaft linking the front and rear transmission units?
Jeff
Jeff
Greenman986S
Engine or gear box mounts?
Engine (are new)Engine or gear box mounts?
An inspection of the external transmission components for wear [all joints and the cardan shaft steady-bearing if there is one] should be your first step. If nothing untoward is found the best way forward is to run the car on a high-speed dyno to replicate the problem in a controlled environment.
Jeff
Jeff
