Notchy Clutch Pedal
- Thread starter dhmatt
pauljmcnulty
bmnelsc
I found that a quick trip to 6000 in third gear with a quick shift to fourth resolved my problem - the release bearing is still noisy but the clutch works smoothly and consistently
So a bit more backround to this topic, the gears have been difficult to select at high revs, fine at lower. I've changed the gearbox oil. Clutch done and flywheel some 20k ago.
The pedal is fine with the engine off and springs back as you would expect and no creaking. No immediate signs of leaks around the master, slave or hydraulic lines but it has now been sitting for a month! The fluid level in the resevoir is still at max.
As the bite point is inconsistant my thoughts are internal seal rupture in either the master or slave?
