Not going backwards
Alpine
I've got a bad judder when I release the clutch, but only when in reverse going backwards. Forwards is fine. Any ideas; is it new clutch time :-( ?
I hope not for your sake mate but I wouldn't rule it out. Clutches can behave very strangely on our cars. You have to remove just about everything that you need to check just to get at the clutch anyway so I would start with the CV joints, then the transaxle and then work your way forward eliminating everything along the way. Check out my post http://www.porscheclubgbforum.com/tm.asp?m=631122&mpage=1&key=&#631122
This may give you a few pointers. There are some similarities to my failure but mine was in all gears and did indeed turn out to be the clutch. Does it motor at proper speed in forward gears? If it does then my opening gambit would be the CV joints or the transaxle. Good luck Phil [:)]
Phil,
On my car I had a problem going in reverse - the rear handbrake springs had broken.
There were no apparent problems going forward but going in reverse the car would rear up on its suspension and display symptoms of a stuck brake once for every wheel revolution. The car is an automatic so no clutch to point the finger at. As I have a gravel drive it was easy to comfirm the problem happened once per wheel revolution.
New rear handbrake springs solved the problem.
Mike
White 2.7 automatic
The retaining handbrake springs break and the bits get trapped in various places and if the the problem has come on suddenly, that would be my guess.
