jemstone29@hotmail.c
Hi All, my 1985 lux does not appear to have any cooling fan. I've let the temp creep up to the red line and no fan has kicked in.
Having read Clark's guide on fault finding, I have uncoupled the two wires from the temp switch in the top of the rad and nothing, both with ignition off which i understand to be low speed nor ignition on high speed. I have replaced the fuse on the board and have done the diagnostics on the relay and this works fine. When I jump the two fan wires I get a little spark so know that power is getting there so I have bought a new second hand fan to replace the one that I don't think is working.
Now my question (sorry for taking so long to get there) is does the slow speed fan resistor if failed stop the fans from working at high speed, I'm not sure from reading the clarks article. ?
I'm sure it is the fan as it is pretty stiff to turn by spinning with the finger with lots of resistance , is this normal or should it spin easlily ?
Cheers as always for the responses
Jeremy
Jeremy
