In addition to the high pitch squelling noise (when applying brakes gently) which I will sort it out later, I have also noticed that there are also other noise during heavier braking - kind of brakes being applied by ABS but you can hear every single operation. Is it the ABS?
Noise when braking
- Thread starter charles.y
The only think I can think you might mean is brake judder, commonly referred to as warped disks but you can feel that through the pedal so I guess you would have mentioned it. The simple solution to brake judder (I found) is to replace the disks & learn to bed them in, more complicated but cheaper might be to have the disks skimmed.
The ABS obviously should only cut in when braking on the limit of traction but again from your description I guess you have ruled that out too.
I think if it were my car I'd check wheel bearings, ball joints & other suspension parts for play.
