Hi all,
This weekend whilst working on the 89' S2, an unusual problem occurred.
My electrics died, and I mean properly died. No clock, nothing. Absolutely zippo. I had the car started a number of times during the morning, moving it about on the driveway etc. Tested all lights, horn and washers. Later on in the morning I had to put the car on ramps, did this and switched it off. I has forgotten to put up the drivers window. Switched the ignition on and nothing happened. No electrics.
I have had time to check very little:
The terminals and clamps around the battery are good, and so is the earth strap to body.
I have some weird current draw somewhere as when you put a multi-meter across the battery you get 12v instantly. When you put it across any other part on the car (going directly from the earth) you get a range of 2 - 10 volts.
I then removed all the fuses except the clock. No clock, odd 10 volt measurement still
I then removed the clock fuse - still no joy.
I then tested across the negative of the battery and the end of the main lead going to the starter motor - you get 10 volts. It you detach the main lead from the starter motor you get an instant 12 volts - good.
I then ran out of time and will pick this up this coming weekend.
My first suspicion is the starter motor, I will bypass this to rule it out.
My second suspicion is could it be the inertia switch? Do these cars even have one?
I will also purchase a 10amp ammeter during the week so I can see how much current is leaking. I also have a variable power supply with voltage and current limiter which can be set.
My main question is :- Has this happened to anyone else?
Any ideas. I'm pretty annoyed
Jev
Jev
