Sandspider
Hi all
Got my car back from my indie today having had the belts, waterpump and rocker cover gasket all replaced - fixing a list of niggles. The garage bloke said it was great - he'd bled it thoroughly, run it for an hour and not a drop of oil or coolant had leaked.
All good thinks me, so I drive it to see a friend, stop for a couple of hours then head home with a couple of miles of spirited driving along the way. But as I get near home, I notice that the temp gauge is much higher than usual - near the top 3rd, where normally it's mid way up the bottom third. Took it the rest of the way home gently (temp gauge stayed high), and switched off. The fans were running, which normally just happens if I'm in creeping traffic or similar. They stopped after a minute or so, so I bled the system again - 30 seconds of steam then water. Thought I'd check the coolant level (the indie said it might need a top up), so I loosened the expansion tank cap only to have a trickle of pink coolant escaping. Before I could tighten it up again, the top of the expansion tank leapt off, and about 2 litres of super high pressure coolant went everywhere. Managed to get the cap back on, then the cooling fans started up again. Bugger. I topped the coolant level back up again, let it cool for half an hour or so, then took it for another drive.
Temp rose quickly again, and the fans kicked in while I was moving to bring it back down to just above the bottom 3rd of the temp gauge. Got it back home, started to loosen the reservoir cap, and saw the pink coolant moving up the tank so tightened it up again sharpish. I opened the bleed screw again, and only steam came out - hardly any water at all. It steamed for two or three minutes, then I tightened it up again, and opened the expansion tank - all normal there now, coolant nicely mixed and stable.
So, my question is (whoops, bit long winded!) do I just need to bleed the car more, or is there a problem? (I read on here that a faulty thermostat can cause header tank pressure - the thermostat was replaced today). I could take it back to the garage of course, but I need to drive to London tomorrow and would rather not have to leave it at the garage again. I could also hear a strange rythmic rubbing noise from the front of the engine when stationary, and the engine sounded a bit harsher than before the work was done (or so I thought - can't be sure now and may be paranoid!).
Thoughts please?
Many thanks.
Thoughts please?
Many thanks.
