New Pads seem too wide?
- Thread starter slickv8
slickv8
Chrishazle
You can also try to fit a junior hacksaw blade between the caliper and shim plate to remove some of the aluminium oxide that has built up.
Hilux
ORIGINAL: wemorgan
Because the pads are wedged shape (narrow at bottom, wide at top) you can file of some of the ends of the pad backing plate, allowing it to drop down further.
Exactly - agree entirely
I used an engineers scribe to scrape out a lot of muck, the plates sprung up still but a bit of judicious grinding on the pad edge meant they fitted perfick and went in and out with a bit of sticktion but nothing major.
